| Version(s): | ALL |
| Area: | License |
| Date Logged & Current Version |
March 2022 42.04 |
What features / licensing choices are available in AutoPIPE Vessel 42.04?
Starting with AutoPIPE Vessel 41.05.00.009 and higher there are 3 types of licenses available:
1. Heat Exchanger
2. Standard
3. Ultimate
The following table lists all features and their availability in each of the AutoPIPE Vessel licenses.
Give attention to item super script notation where indicated, details at the bottom.
AutoPIPE Heat Exchanger |
AutoPIPE Standard |
AutoPIPE Ultimate |
ASME VIII (US design code) 3 |
PD5500 (British design code) 3 |
CODAP (French design code) 3 |
AD-Merlbätter (German design code) 3 |
EN 13445 (European design code) 3 |
GOST (Russian design code) 3 |
GB (Chinese design code) 3 |
Pressure Vessel Design & Analysis |
Shell and Tube Heat Exchanger Design & Analysis |
Storage Tank (API 650) Design & Analysis |
Air Cooler (API 661) Design & Analysis |
Boiler (NFE) Design & Analysis |
Chimney Design & Analysis |
SolidWorks – 3D ONLY (sldprt, sldasm file creation) 1 |
Export/Import to PDS |
IFC File Export |
Microstation - 2D, 3D (dgn file creation) 1 |
AutoCAD - 2D, 3D (dwg file creation) 1 |
Local Load 2 |
Expansion Joint and Bellows Design (including TEMA 9th FEA method) 2 |
Tubesheet layout (no tubesheet calculations, only layout design) 2 |
Anchor Base 2 |
Shell / Head / Cone / Flange 2 |
Beam design 2 |
U Bend 2 |
Flat plate with stay bolts 2 |
Cost Estimate |
Fatigue Analysis |
Motion Analysis |
Blast Analysis |
Wind, Vortex shedding, Seismic Calculations |
Support and Lifting Accessories Calculations |
Compress file import (build 7510) |
AutoPIPE Nozzle Load Import |
Import of Aspentech and HTRI files |
PXF file import export |
Platform, ladders modeling, external loads |
External loads, structural and piping clips, packing, trays, coil, stiffeners |
(1)
a) AutoPIPE Vessel uses a CAD plugin to create drawings, therefore a cad program (ex. AutoCAD, Microstation, Solidworks, etc..) must have been installed before trying to export the respective drawing from AutoPIPE Vessel.
b) CAD export capability will be limited only to the type of equipment that can be modeled while using a Standard or Heat Exchanger or Ultimate license version of the program.
Example:
With Vessel Standard license enabled, user cannot export a Shell & Tube heat exchanger model to drawings. User must have a Vessel Ultimate or Heat Exchanger license enabled to export a Shell & Tube heat exchanger model to drawings. Because, Shell & Tube heat exchanger can only be modeled with an Ultimate or Heat Exchanger license and not a Standard license.
(2) Individual component modeling / calculations can be performed instead of full equipment modeling and design.
(3) Choice of one code (per user’s choice and as mentioned in license agreement) is included in the license for Vessel Standard or Heat Exchanger. However, the user may select more than one code in which case they will be charged separately for the code that is NOT covered in the license. Conversely, Ultimate license includes ALL the design codes.
License Configuration - What do you see
Subscription Entitlement Service
