| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | General |
| Date Logged & Current Version | April 2019 12.00.00.14 |
Why does AutoPIPE ignore axial force in most of the code equations?
Confirm the model is considering axial force, as this option by default is turned OFF. See Tool> Model Options> Results> "Include axial force" option
Excerpt from online help:
The piping codes ignore the effect of axial force for calculating stresses in the sustained and occasional categories (only bending moments are considered, see Code Compliance Calculations). This option has been provided to allow the inclusion of axial force effects. By default this option is unchecked....
See online help for more information on this option.
