- General FAQ's about Piping Code Calculations
Comments, Questions, and Answers about General piping code calculations in AutoPIPE
Item #1: Ignore axial force
Item #2: Which offshore design should be used?
Item #3: Accuracy rating for results
Item #4: Russian Codes (and ASME equivalents)
Item #5: Project documentation requires specific Piping Code and material library code year
Item #6: Calculate Wall Thickness
Item #7: Axial force (FX) be about the same for different lengths of straight pipes
Item #8: Calculate MAWP
Piping Code Calculations - AutoPIPE
