ADO application
| 801331 | Soil ID input grid: PGV value cannot be modified, instead of PGV the PGA value is updated |
| 781999 | Time history Location dialog does not accept beam nodes |
TFS application
| 637020 | Buoyancy is not applied to copied segments |
| 241311 | ISO14692: Pressure correction factor for bend flexibility factor is applied incorrectly |
| 259941 | ISO 14692: Incorrect factor is being used for calculating bend flexibility factor for hand-lay smooth bends |
| 213249 | Incorrect stress value may be stored for SLO(B2) combination for JSME Piping code |
| 208437 | Incorrect modulus values for ISOGRPM library |
| 139144 | Temperature dependent data not updated on modifying temperature for points range |
| 139025 | Incorrect SAM displacements for JSME 2008 with more than 2 support groups |
| 139027 | Incorrect mapping of support groups when changing JSME edition from 2008 to 2005 |
| 138754 | Bend near point does not use SIF value for Adams Method ASME NC/ND |
