ADO application:
| 748523 | Sorted stress report and color plots may not display the +ve face of a bend midpoint which may give incorrect maximum stress |
| 739795 | Rotating Equipment: Override Nozzle Coordinates checkbox may fetch incorrect equipment nozzle offset values |
| 675378 | EN13480: Allowable for sustained and occasional categories may be set to zero when pipe material has temperature range limited to a temperature less than operating |
TFS application
| 1124391 | Flange Check: Gasket Inside Diameter and Effective Width values may not be correct |
| 1054789 | Flange Check: Capability to assign flange corrosion for flange design is not available |
| 984316 | Flange Check: Flange inserted on a segment junction/continuation point may use zero values for external forces and moments for the selected Load Combination |
| 890784 | Flange Analysis: When internal pressure is set to zero, stresses due to external loads are not calculated |
| 889026 |
| 138814 | Flange Analysis: Bolt Spacing Correction Factor may calculate incorrectly |
| 138810 | Sustained allowable for B31.1 & B31.3 may be incorrect when Circ. W fac. applied |
| 138808 | B31.3-2010 Occasional allowable may be unconservative for T<Tcr or Tcr=0 |
| 138694 | Creep for 1.49XX material in EURO2009 using incorrect data from German version |
| 138271 | Two flanges added to a component may incorrectly share the same flange data |
