| Product(s): | RAM Modeler | ||
| Version(s): | 14.06.00.00 | ||
| Environment: | Windows 7 | ||
| Area: | Installation | ||
| Original Author: | Jeremy Hoesly, Bentley Technical Support Group |
During installation, the following error occurs which when dismissed, rolls back the installation:
An error occurred during the installation of assembly 'Microsoft.VC80.ATL,type="win32",version="8.0.50727.762",publicKeyToken="1fc8b3b9a1e18e3b",processorArchitecture="amd64". Please refer to Help and Support for more information. HRESULT: 0x80070BC9.
Some Microsoft assemblies included with RAM Structural System are failing to install because a previous version of the assemblies could not be removed. Because of this, the RAM Structural System installation is canceled and rolled back.
Removal of the older assemblies will resolve the problem. By default, Windows retains older versions of assemblies even when they are superceded by newer versions later. Windows provides a cleanup option to remove unused assemblies, however. To perform this cleanup, please perform the following steps:
[[SELECTsupport TechNotes and FAQs]]
