04-01. AutoPIPE.INI file details
Problem:
What is the AutoPIPE.ini file and what can I do with it?
Answer:
An *.INI is a file extension for an initialization file format, as the name implies INI files are plain text (ASCII) and are used to set parameters for programs like AutoPIPE. This file can be opened and modified by any text editor program like Notepad, MS Word, Ultra Edit, etc. However, be warned that if the file is modified incorrectly AutoPIPE may not open or function correctly. Any modifications from the original file will be at your own risk.
The INI file is broken up into 13 sections, each section starts with a name in square brackets (ex. [view]). Each section will have one or more settings that can modified. Some of these changes may become apparent when the application is started, while others are not so apparent.
+++Warning+++: be careful and exact in any changes made to this file.
Category
Edition
Title / AutoPIPE version 1st appeared
[Main]
  UseOpenGL Default = 1
UseCOMDlg Default = 0
UseGrids Default = 1
UseEigExp Default = 0
Include_WIP Default = 0
OldVersionNote Default = 1
UnhideSectionColumns Default = 0
ShowUserInfoDialog
Default = 1
Description
Displays the Model File Properties dialog.  The Model File Properties dialog includes:
  • General information about the model, i.e. model name, the username that was the last to save the model, and the model revision number.
  • Time information associated with the model, i.e. when it was created, modified, and last accessed.
  • Disk information, which provides the file location, and size of the model file.
Option = 0 or 1 (Off or On respectfully)
BendRadius
Default = Long
Description
The bend radius defines the near and far points of the bend. This will set the default setting when Bend dialog is initiated.
Option
  • Long (radii 1.5 times the nominal pipe diameter)
  • Short (radii 1.0 times the nominal pipe diameter)
  • 3D (radii 3.0 times the nominal pipe diameter)
  • 5D (radii 5.0 times the nominal pipe diameter)
  • Users can also input a custom, non-standard radius
ASMEDiv2CodeYear Default = 2010
Export_SQLITE_Db Default = 1
Export_SQLite_SelectAll Default = 0
Export_SQLite_Input Default = 1
Export_SQLite_Result Default = 0
Export_SQLite_HangerResult Default = 0
Export_MSWord Default = 1
Export_Open_DB Default = 1
Launch_Open_DB Default = 1
Keyboard_Listener Default = 1
OverwriteCheckPrintHeaderFirstPage Default = 0
[StressIso]
  IniPath=stressiso.ini
Default = Blank
Description:
Stores the last valid location used for Stressiso.ini
Option = valid filepath to stressiso.ini
LastAPISOPath Default = Blank
FileExtension Default = Blank
[ScaleFactors]
  LineAnchors
Default =
  • LineAnchors- Default = 1.000000
  • LineSupports- Default = 1.000000
  • LineFlanges - Default = 1.000000
  • LineForces - Default = 1.000000
  • LineDisplacements - Default = 1.000000
  • LineWeights - Default = 1.000000
  • Line2Point - Default = 1.000000
  • LineWaveAnchors - Default = 1.000000
  • LineLocalAxes - Default = 1.000000
  • SolidAnchors - Default = 0.000000
  • SolidSupports - Default = 0.000000
  • SolidFlanges - Default = 0.000000
  • SolidForces - Default = 0.000000
  • SolidDisplacements - Default = 0.000000
  • SolidWeights - Default = 0.000000
  • SolidWaveAnchors - Default = 0.000000
  • SolidLocalAxes - Default = 0.000000
Description
Enables setting of Support and Axis Scale Factors to be used during Single Line (Anchors, Supports, Flanges, Displacements, Concentrated Forces, Weights, 2pt Components e.g Valves, Reducers) or Solid / Wireframe graphics mode(Anchors, Supports, Flanges, Displacements, Concentrated Forces, Weights).
Option
  • Valid scale factors = 0 to 10
  • Single line - This scales the out of plane dimension of components and data in proportion to the displayed text height. This results in better visualization and a less cluttered view of the model while in single line mode. Scaling may be further customized by specifying a value not equal to 1. Larger values than 1 increase the component and data size and smaller values reduce the component and data size.
  • Wireframe / Solid - When the scale factor is set to zero, the symbol size will be drawn proportional to the pipe OD. When the scale factor is greater than zero, the scale factor is applied to a predetermined size for the symbol.
LineSupports
LineFlanges
LineForces
LineDisplacements
LineWeights
Line2Point
LineWaveAnchors
LineLocalAxes
SolidAnchors
SolidSupports
SolidFlanges
SolidForces
SolidDisplacements
SolidWeights
SolidWaveAnchors
SolidLocalAxes
[LocalAxes]
  LocalAxesShow
Default = Blank
Description:
When On, display of the local axes.
LocalAxesTextLabels
Default = 1
Description:
When On, display of labels with local axes (ex. x,y,z).
LocalAxesSkipDraw
Default = 0
Description:
When turned on will not draw for a node if the local axis symbol cannot fit in its boundaries. This is to avoid clutter in the drawing of the model. If set to OFF, local axes symbols will be drawn for all the nodes.
LocalAxesPipe
Default = 1 (all)
Description:
When turned OFF, local axis will be displayed on the component, ex.
When turned ON, local axis not displayed, ex.
LocalAxesReducer
LocalAxesFlexibleJoint
LocalAxesValve
[WindowPosition]
  iTwinWindowPosition Default = Blank
[View]
  IsoViewDir Default = 1
ShowTeeArrows Default = 1
ShowOrigin Default = 0
RefreshGraphicsOnLoad
Default = 0
Description:
Blank program screen or non-refreshing graphics may appear on some machines. A graphics fix only to be enabled for machines facing graphics refresh issues.
Windows7Basic Default = 1
[DialogDimensions]
  DlgFlngAnalysisWidth Default = 0
DlgFlngAnalysisHeight Default = 0
DlgFlngAnalysisMaximized Default = 0
[DeformXYZ]
  EnableXYZ Default = 0
LineStyle Default = 2
LineColor Default = 1
LineWidth Default = 1
[PipeLink]
  ImportSupportReactions Default = 0
[OnlineResources]
  ProductInfo Default = AutoPipe.ProdPage
Community Default = AutoPIPE.Community
Forum Default = AutoPipe.Forum
OnDemandSeminars Default = AutoPIPE.Videos
UpcomingEvents Default = AutoPIPE.Webinars
Training Default = AutoPIPE.Training
TechnicalSupport Default = AutoPIPE.TechnicalSupport
AboutConnect Default = Connect.Community.Overview
SOExpiration Default = AutoPIPE.SOv11.5.Expiration
Ideas Default = AutoPIPE.Ideas
APLinkedIn Default = AutoPIPE.LinkedIn
APYouTube Default = AutoPIPE.YouTube
[DefaultOnlineResources]
  ProductInfo Default = https://www.bentley.com/en/products/product-line/pipe-stress-and-vessel-analysis-software/autopipe
Community Default = https://bentleysystems.service-now.com/community?id=autopipe_landing_page
Forum Default = https://bentleysystems.service-now.com/community?id=community_forum&sys_id=3f00f3ca1b1a3110f3fc5287624bcbf4
OnDemandSeminars Default = https://eventhub.bentley.com/wcc/eh/2541253/category/37129/on-demand-webinars
UpcomingEvents Default = https://www.bentley.com/events/overview/
Training Default = https://learn.bentley.com/app/Public/BrowseLearningPaths?CustomLP=False
TechnicalSupport Default = https://bentleysystems.service-now.com/community?id=kb_article_view&sysparm_article=KB0115375
Ideas Default = https://autopipe-brand.ideas.aha.io/
APLinkedIn Default = https://www.linkedin.com/groups/10355506/
APYouTube Default = https://www.youtube.com/channel/UCMKC7w_sQHymmq_eSy7dALw
[PointSearch]
  Tolerance Default = 6.000000
[CADMapping]
  LineNumberAttribute Default = MISC-SPEC1
LineClassAttribute Default = PIPING-SPEC
PIPELINEREFERENCE Default = Blank
[ForcesMomentsReport]
  ShowPipeIDsOnBothSidesOfNode
Default = 0
Description:
This feature is not available at Default, user have to switch it on manually by altering file AutoPIPE.INI.  When this flag equals to 1, Forces and Moments report will display both Pipe IDs (Previous and Next) attached to each side of node. When this flag equals to 0(Default), program will retain previous behavior as no change in Forces and Moments report.
Moreover, if Previous/Next point of +/- face of node is Tee, then Previous/Next pipe will be set to "Tee" in report.
[ASCE2005SoilCalculation]
  CalculateWeightOfSoilPerExactCodeEquation Default = 1
[PRCI2009SoilCalculation]
[COG]
  SymbolSize Default = 15.000000
[EngineeringConstants]
  AccelerationDueToGravityfeetpersec2 Default = 32.200000
DensityOfWaterSpecificGravCalcpoundperft3 Default = 2.400000
DensityOfSeaWaterpoundperft3 Default = 62.400000
DensityofWaterBuriedPipingpoundperft3 Default = 62.400000
[IsmSettings]
  IsmLogging Default = 0
ShowStructuralSynch Default = 0
MapParametricToNonstandardSection Default = 1
[LogFilterRange]
  LogFilterStart Default = 1
LogFilterEnd Default = -1
[OpenRecentModels]
  ShowOpenRecentPreview
Default = 1
[Caching]
  EnableSQLiteCaching Default = 1
[Version Settings]
  DEFAULT_EDITION
Default = 0
Description:
This feature controls which AutoPIPE license edition is selected by default when the program starts.It allows administrators and users to define the default license edition that AutoPIPE will attempt to use during startup, subject to license availability.
The available values correspond to the following license editions:
Option =
0 - Demo
1- AutoPIPE (Standard)
2-  AutoPIPE Advance
3-  AutoPIPE Advance + KHK2 Add-on
6-  AutoPIPE Nuclear + KHK2 Add-on
[FeatureToggles]
  IFT_111597 Default = 0
Settings - AutoPIPE
