05. Export Enhancements & Defects for AutoPIPE
Note: if an enhancement or defect has not been added to the program, log an Service request for that enhancement. The more requests logged per an enhancement, the quicker the CAE development team will add that feature to the program.
The following enhancements and defects have already been requested:
Bug 909173
DGN export from 12.8 does not export layers for insulation as in earlier versions
Feature 860788
Add option to rotate the model to better match AutoCAD DWG axis
Feature 860788
Bug 774245
Upgrade DGN platform
Feature 789190
Export DXf model with support text only
Bug 644574
DXF Export: The beam and associated components are disoriented
Defect 1024976
Export input mdb: pipe id is -1 in Pres/Temp/PipeID table
Enhancement 942310
Indicate units for each column in the exported results / input database (*.mdb) files
Enhancement 891185
Add feature to map layer colors for exported DXF files
Enhancement 681351
Set Results database filename to systemname_results.mdb
Enhancement 681351
Add feature to expose Node numbering offset for export to CII files
Defect 666513
Export to Pipelink may not export correct node names to STAAD in case of numeric node numbers
Enhancement 659957
Save model as ADL Pipe format
Defect 538528
CAESAR Export: Large coordinates of segments not exported correctly
Enhancement 468340
Importing Reaction of Combination load cases of AutoPIPE in STAAD.Pro
Enhancement 372344
Export model to caesar CII 7.0 file format
Enhancement 152519
Results Database should be updated to be compatible with Office 2013
Enhancement 138809
Export Input and Results database as a *.ACCDB file instead of *.MDB
Enhancement 105400
Export General Stress results output sub-report to MDB file
Enhancement 98634
Add options to export Beams to STAAD using pipelink
Enhancements Requests and Logged Defects
