11. Pipe and Piping Components Enhancements & Defects for AutoPIPE
The following enhancements have already been requested:
Note: if an enhancement has not been added to the program, log an Service request for that enhancement. The more requests logged per an enhancement, the quicker the CAE development team will add that feature to the program.
Bug 1939536
Incorrect pipe size and material in TEE DATA LISTING report
Feature 1089332
Add a Jacketed (double wall) Piping component
Bug 959774
Program crashes on editing any node after editing tee point
Enhancement 1089332
Add SIF information to Bend dialog / input grid
Enhancement 919398
Add feature to automatically split all runs into user defined number
Enhancement 138680
Add features to include Type A/B fitting pressure factor for En13480 piping code
Workaround: model as a 4 point tee with the correct pipe properties and pressure settings. Set type of tee to one closely associated with a similar SIF calculation, or select Tyep = User and enter in hand calculated SIF values.
Enhancement 1045515
Add feature to update default Mil tolerance across all Pipe IDs
Enhancement 858078
For Generic Non-Standard valves add a drop down listing for main end connection and pressure rating
Defect 695601
Valve Dialog: Cannot insert valve before a point
Enhancement 570606
Add feature to account for default / User define gasket width when inserting a flange
Enhancement 394189
Converting units from Imperial to SI
Enhancement 391340
Add CryoGelZ insulation
Enhancement 344955
Increase the Material ID character count
Defect 341498
Modifying pipe properties over range does not update the bend radius for Short, 3D and 5D bends
Defect 187051
Point having extra data cannot be converted to other types
Enhancement 146516
Treat tee as a components similar to a bend
(4 point tee)
Enhancement 142327
Add feature to calculate SIF and SSI per WRC 329
Enhancement 139098 :Tracker#: 11098
Add option to apply lining stiffness
Enhancement 139059 :Tracker#: 11056
Add new valve type library for Press Safety / Relief Valve (PSV or PRV)
Enhancement 138419 :Tracker#: 10336
 Add new butterfly valve type library
Enhancement 138391 :Tracker#: 10303
 Flexible joint: add constant stiffness option
Enhancement 126980
Add friction force value to over come before flexible joint movement
Enhancement 110562
Increase the length of the pipe identifier name from 8 to 16 characters
Enhancement 109145 :Tracker#: 4444
Add ability to plot a true eccentric reducer
Enhancement 108453 :Tracker#: 4779
Ability to model breaking load for ball joints
Enhancement 102674 :Tracker#: 941
Add 2 point flange
Enhancement 98527
Add a Flexible / Expansion joint output report
Enhancement 79346
Add option to apply an SIF to one or both sides of a node point
Enhancements Requests and Logged Defects
