| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Import |
| Date Logged & Current Version | March. 2022 12.07.00.346 |
The following appears while using AutoPIPE:
W2164-198:Tee header and branch missing information has been updated on the following point(s):
why?
In one scenario, this message is displayed while importing a file into AutoPIPE. As the message indicates, because there was insufficient information default values were used as needed.
Example:
Imported information:
Import PCF file translated to NTL file
Reference Batch NTL cards in AutoPIPE help for information required by the program.
AS one can see the Bach file has a number of required settings when modeling a Tee. However depending on the tee being modeled, not everyone one of these settings are required. Depends on; the piping code selected for the model, "Tee Component", "Type of tee", etc...
Warnings Messages displayed in AutoPIPE
