| Version(s): | All | ||
| Area: | Design | ||
| Subarea: | American Steel Design | ||
I want STAAD.Pro to perform a steel design based on the LRFD 3rd Ed rather than the 2nd Edition. The output always says "LRFD 1994". How do I tell it what code to use?
If you wish to use LRFD 3rd Edition Code, you can write CODE LRFD3 when providing the design parameters.
The 3rd edition of the American LRFD steel code has been implemented along with the 2nd edition. In general, the principles outlined in the code for design for axial tension, compression, flexure, shear etc., are quite similar to those in earlier versions of the code. The major differences are in the form of incorporation of the Young’s modulus of steel in the various equations for determining various limits like slenderness and capacities.
Consequently, the general procedure used in STAAD for design of steel members per the AISC-LRFD code has not changed significantly. Users may refer to Section 2 of the STAAD.Pro Technical Reference manual for these procedures.
Those who wish to use the 1994 edition of the code can still do so by specifying the code name as:
CODE LRFD2
An example of commands used for performing design based on the new and old codes are as shown.
Example for the LRFD-2001 code (3rd Ed)
UNIT KIP INCH
PARAMETER
CODE LRFD
or
CODE LRFD3
FYLD 50 ALL
UNT 72 MEMBER 1 TO 10
UNB 72 MEMB 1 TO 10
MAIN 1.0 MEMB 17 20
SELECT MEMB 30 TO 40
CHECK CODE MEMB 1 TO 30
Example for the LRFD-1994 code (2nd Ed)
UNIT KIP INCH
PARAMETER
CODE LRFD2
FYLD 50 ALL
UNB 72 MEMB 1 TO 10
MAIN 1.0 MEMB 17 20
