| Version(s): | All | ||
| Area: | Design | ||
| Subarea: | American Steel Design | ||
In STAAD/Pro 2000 and STAAD.Pro, I no longer see the UNL parameter for the AISC ASD and LRFD codes. Instead, I see the parameters UNT and UNB. Why?
In versions of STAAD prior to STAAD/Pro 2000, the mechanism for specifying the unsupported length of the compression flange was through the means of the UNL parameter. However, the drawback of this command is that if the value for the top flange is different from that of the bottom flange, there wasn't any means to communicate that information to STAAD.
Consequently, 2 new commands were introduced, namely, UNT and UNB.
UNT stands for the unsupported length of the TOP flange of the member for calculating the capacity in bending compression and bending tension.
UNB stands for the unsupported length of the BOTTOM flange for calculating the capacity in bending compression and bending tension.
To avoid the confusion that may arise from having 3 separate parameters to specify 2 items of input, we no longer mention the UNL parameter. However, to enable the current versions of STAAD to analyze input files created using the older versions of STAAD, the UNL parameter continues to work the way it did.
These 2 new parameters are to be used in place of UNL. If UNT/UNB is specified in addition to UNL, UNL will be ignored. If neither UNT nor UNB are specified, but UNL is specified, the value of UNL will be used for both top and bottom flange.
