| Version(s): | All | ||
| Area: | Design | ||
| Subarea: | American Steel Design | ||
Will STAAD explicitly state that the beam has passed the deflection criteria?
When STAAD performs steel design (code checking as well as member selection), it checks several conditions required by the code. The one which gives rise to the highest unity check is the one determined as critical. If the deflection criteria ends up being the worst condition, you will see it being reported as the critical condition.
You can verify whether a member has passed the deflection check by looking at the terms "DFF" and "dff" in the steel design output. "DFF" is the value you input. "dff" is the value the program calculates as the actual "L/d" ratio. If "dff" is larger than "DFF", the member is deemed safe for deflection.
