| Version(s): | All | ||
| Area: | Design | ||
| Subarea: | American Steel Design | ||
I run the analysis of a 3-D bridge truss model and requested a CODE CHECK of the members. The results of this code check do not correspond to my hand calculation results.
The results of this code check show some very strange numbers in as far as code ratio using AISC- H1-1 formulation is concerned. Reference result output for members number 62 to 74 for example. Other ratios do not seem right either.
If you look at the AISC equation H1-1, you will find that there are 2 terms in the denominator, called
(1-fa/Fey)
and
(1-fa/Fez)
If the value of fa equals or exceeds Fey or Fez (Euler stresses), the respective terms become zero or negative, which is not a desirable event. In such a situation, STAAD replaces that negative number with the value 0.0001. The consequence of this is that, that part of the interaction equation becomes magnified by 10000, which will cause the overall value of the left hand side of equation H1-1 to increase significantly.
The above scenario is what occurs in the case of several of the members in the list 62 to 74. If you want to obtain proof of this, you may do the following. Change the value of the TRACK parameter from 1 to 2, and you will get a more detailed design output. That output will include the values of fa, Fey, Fez, etc.
To remedy the problem, you need to use a larger cross section so that "fa" becomes smaller, or use one with a smaller KL/r value so that Fey and/or Fez become larger.
