| Version(s): | All | ||
| Area: | Design | ||
| Subarea: | American Steel Design | ||
The KL/r value that STAAD reports for a single angle member does not match my hand calculation. Design is per the AISC ASD 9th edition code.
A single angle is subjected to 2 buckling modes :
You should check whether the flexural torsional buckling mode governs in your case. The KL/r calculated for the flexural torsional mode, if it happens to the largest of the 3 values, is reported only with a TRACK 1.0 detail of output. It does not get reported for TRACK 0 or TRACK 2 level of detail of output. In other words, if you want to see the KL/r in the flexural torsional buckling mode, use the parameter TRACK 1.0.
