| Product(s): | STAAD.Offshore | ||
| Version(s): | All | ||
| Area: | STAAD.Offshore | ||
| Subarea: | Wave Loads | ||
| Original Author: | Sudip Narayan Choudhury Bentley Technical Support Group | ||
When I generate the STAAD file with wave loads using the STAAD.Offshore module, the file throws up errors while opening in STAAD.Pro and the Wave Load Cases are messed up.
This is most likely due to the fact that you have specified the first wave load case number such that either that case number or the subsequent wave load case numbers match with primary or combination load case numbers in the original file. If this is the reason then you need to specify the wave load case number in such a way that there is no duplication.
