| Product(s): | STAAD.Offshore | ||
| Version(s): | All | ||
| Area: | STAAD.Offshore | ||
| Subarea: | N/A | ||
| Original Author: | Sudip Narayan Choudhury Bentley Technical Support Group | ||
Is it possible to specify the heave + roll and heave – roll in the same load case?
You cannot create heave + roll and heave – roll in the same load group. You need to create two different groups with the directional factor as + 1 for heave + roll case and -1 for heave – roll case.
In the STAAD file however, you can manually edit the load cases two specify all the load items in the same load case – however, doing that you run the risk of under estimating the inertial forces.
