| Product(s): | STAAD.Offshore | ||
| Version(s): | All | ||
| Area: | STAAD.Offshore | ||
| Subarea: | N/A | ||
| Original Author: |
Sudip Narayan Choudhury | ||
When I generate the _Wave.std File using STAAD.Offshore, I encounter a lot of messages like the following. What did I do wrong?
**WARNING** TRAP LOAD BEYOND ITS LENGTH. FULL LENGTH ASSUMED. MEMB aaa CASE bb
What you encounter is most probably due to an erroneous version of OpenSTAAD OEM packaged with your STAAD.Pro installer. This is most likely to happen if you have installed STAAD.Pro SS5 in your system. Please install the SS6 version of STAAD - which has the fixed version of OpenSTAAD OEM.
