| Product(s): | STAAD Foundation Advanced | ||
| Version(s): | ALL | ||
| Environment: | ALL | ||
| Area: | General | ||
| Subarea: | Report | ||
| Original Author: | Sye Chakraborty Bentley Technical Support Group | ||
Do I have any control over what is included in the calculation sheet ?
OR
Can I customize the calculation sheet in SFA ?
STAAD Foundation Advanced does offer report customization options for certain job types like isolated footing. When in the calculation sheet, one can use the check boxes inside the Data Input Pane on the right to control what is included in the calculation sheet.
The customization options can be brought up by clicking on the Report Customization option in the ribbon menu at the top of the graphics screen.
Report customization will be available for all other foundation types in future but for now, if you are using some other foundation types, your only option to control the output is to copy the contents of the calculation sheet and paste it in a document editing software like MS Word and then manually editing the content. You can use standard windows functionalities to copy and paste the data from inside the calculation sheet for example CTRL+A to select the content, CTRL+C to copy the content and CTRL+V to paste the content in the other software.
