| Product(s): | STAAD Foundation Advanced | ||
| Version(s): | ALL | ||
| Environment: | ALL | ||
| Area: | General Foundation | ||
| Subarea: | Combined Footing | ||
| Original Author: | Sye Chakraborty Bentley Technical Support Group | ||
I am trying to design a combined footing with 4 supports (all supports). I received an error saying "ALL SELECTED SUPPORTS ARE NOT COLLINEAR AND PARALLEL TO GLOBAL AXIS. CANNOT CREATE COMBINED FOOTING. I checked my supports and all of them are at y=0.
For a combined footing to be created in STAAD Foundation Advanced, the supports need to follow two conditions
So even if you may have all supports at the same Y elevation, your supports may not satisfy one or more of these criteria, in which case such a message will be provided. For such cases you may use the mat foundation job instead and model the combined footing as a mat.
