| Product: | Ram Concept | ||
| First Affected Version: | |||
| Found in Version: | 06.00.01.006 | ||
| Fixed in Version: | |||
| Environment: | All | ||
| Area: | Import/Export | ||
| Subarea: | N/A | ||
| Issue #: | 344337 |
A "File is Not Recognized Format Error" is produced when attempting to import a drawing file into RAM Concept.
The error occurs on some machines when the drawing file is saved on a network drive. The cause of the error is unknown. Saving the file to a local drive and then importing the file will prevent the error from occurring.
