| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Report |
Date Logged & Current Version | Sept 2022 42.04.00.092 |
Problem:
See attached report page 14 there is a total calculated stress of 433.99 Mpa bigger than 414 Mpa
What is the allowable for this? assuming 414 MPa. correct?
Why is it not indicated that this may be larger than the allowable?
Please read the report, in bold it is clearly indicated that the Nozzle stress is calculated for information only.
So, the stress is compare to nothing as it is informative.
No defect.
