Applies To | |||
Product: | RAM Concrete | ||
First Affected Version: | |||
Found in Version: | 14.06.02.00 | ||
Fixed in Version: | |||
Area: | Design | ||
Issue #: | 123374 |
The program designed concrete columns for an incorrect shear demand (Vu) when all of the following conditions occurred:
The problem affected all ACI design codes.
Columns that are part of intermediate or special moment frames must be designed for a shear demand associated with probable flexural strength (Mpr). When determining Mpr, the program looked at the top and bottom of each column segment and did not consider the bracing condition at each end of the segment. When one end of the segment was not braced, as would occur when no beam frame into the column, the program returned a value of 0 for Mpr.
We are working on a fix for this problem.
