c. V-stop - Support Type in AutoPIPE - FAQ's
Comments, Questions, and Answers about AutoPIPE's Line Stop Support Type:
Item #1: Questions about V-stop support dialog screen
Item #2: Do we have any control to adjust V-Stop support stiffness (or) always it takes (default) rigid value.
Answer: No, an AutoPIPE V-stop has rigid stiffness setting. If you wish to consider a V-stop with support stiffness, select Support type = Incline.
Item #3: Model Vertical Rod support in AutoPIPE
Item #4: Soil over concrete pier type supports
Item #5: Roller Support
Item #6: Rest Block
Different Types of Supports
