| Product: | STAAD.Pro | ||
| First Affected Version: | |||
| Found in Version: | 20.07.10.41 | ||
| Released in Version: | 20.07.10.66 | ||
| Environment: | All | ||
| Area: | Editor | ||
| Subarea: | N/A | ||
| Issue #: | 256799 |
STAAD.Pro crashes when a model referencing EXTERNAL USER PROVIDED TABLE ( .UPT file ) is modified using the text editor mode followed by SAVE ->File->EXIT.
One needs to write the user table property data in the editor itself as opposed to referring the external upt file. Section 5.19 of the Technical Reference Manual describes how each section type can be defined.
The issue has been addressed in version 20.07.10.66
