Applies To | |||
Product: | STAAD.Pro | ||
First Affected Version: | 20.07.11.70 | ||
Found in Version: | 20.07.11.70 | ||
Released in Version: | 20.07.11.82 | ||
Environment: | All | ||
Area: | Design | ||
Subarea: | AISC 360-05/10 | ||
Issue #: | 447990 |
Double Channel Front to Front cannot be designed as per AISC Unified 360-05 and 360-10 codes. An ERROR: MEMBER DESIGN FAILED FOR MEMBER xx is reported
Such sections can be designed in older versions of STAAD.Pro like SS5 ( 20.07.10.65). So use an older version to design these sections.
This is addressed in 20.07.11.82
