Applies To | |||
Product: | STAAD.Pro | ||
First Affected Version: | 20.07.11.45 | ||
Found in Version: | 20.07.11.45 | ||
Released in Version: | 20.07.11.50 | ||
Environment: | All | ||
Area: | Analysis | ||
Subarea: | N/A | ||
Issue #: | 323889 |
STAAD.Pro is not able to read the external user table files and is generating errors like
*** ERROR : FILE NOT FOUND C:\...\...
**ERROR- IN READING MEMBER PROPERTIES. CHECK DATA FORMAT CAREFULLY.
Run analysis on a model which refers to an external user table file.
Above errors appear during analysis.
Ensure that the upt file is in the same folder as the STAAD.Pro model.
Provide the full path name to the file. For example instead of specifying
START USER TABLE
TABLE 1 wf1.txt
END
specify the input as shown next
START USER TABLE
TABLE 1 C:\Model_folder\wf1.txt
END
The issue is addressed in 20.07.11.50
