Answer:
Given the vessel is 6040mm dia with a wall thickness = 20mm and Limpet / Half pipe coli with a pitch of 150 mm and 40 mm radius.
Referencing, ASME VIII Div 1, appendix EE, figure EE-2 (DN80), the K factor would be read, but parameter D is beyond the scope of the limits of the chart (D = 6040 mm / 25.4 mm = 237.79 in).
Other applications like PV Elite considers the Diameter D = 170 instead of 237.79, then they have a K value found from reading the chart. However, as mentioned, the actual geometry is beyond the chart.
How to best find the correct value of K ?
Upon further investigation of:
a. b. ASME VIII div.1 NONMANDATORY APPENDIX EE HALF-PIPE JACKETS,
b. ASME VIII div.2 4.11.5 DESIGN OF PARTIAL JACKETS
Find that ASME VIII div.2 4.11.5 uses equations instead of charts to determine the K factor.
