| Product: | STAAD.Pro | ||
| First Affected Version: | 20.07.11.33 | ||
| Found in Version: | 20.07.11.33 | ||
| Released in Version: | 20.07.11.50 | ||
| Environment: | All | ||
| Area: | Modeling | ||
| Subarea: | N/A | ||
| Issue #: | 264569, 336157 |
Inclined members are not being split through Geometry > Intersect Selected Members > Intersect.
Note that the members are not split at the intersection.
1. Open the program and go to configuration
2. Set the base unit as English.
3. Open the model and go to the top menu option View > Options > Tolerance
4. Set it to 0.1 inch and click on Apply > Ok
5. Select the members and try to intersect them by going to Geometry > Intersect Selected Members > Intersect. Enter a tolerance of 0.1 inch.
The issue is addressed in 20.07.11.50
