| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Import |
| Date Logged & Current Version | Oct 2022 12.08.03.015 |
One or both of the Standard and/or check box to the right may be greyed out on the "caesar II Import Flange Settings" dialog when importing a CII file into AutoPIPE, why?
Example:
This is controlled by the "#$ IMPFLANGE" setting located in the CIIMAP file which is stored in the "User Profile Path" of AutoPIPE.
Currently set to "JIS_B_2200_2004 " (defult setting = B16-47 2006 & B16-5 2009).
This tag defined in ciimap file. which makes the combobox disable if the standard is B16-47 2006 & B16-5 2009 in the map file.
CII Import Issues and FAQ's with AutoPIPE
