| Product(s): | RAM Elements | ||
| First Affected Version: | 13.03.00.117 | ||
| Found in Version: | 13.03.00.117 | ||
| Fixed in Version: | 13.04.00.164 | ||
| Area: | Design | ||
After designing an integrated wall or footing using a Ram Elements model, it appears that the final design is saved, but when that wall or footing is rechecked, all saved changes are lost.
This is a defect in version 13.03.00.117 only. Install any version after 13.04 to correct behavior.It affects these integrated modules:
