16. Grids (Input & Results) Enhancements & Defects requests for AutoPIPE
Note: if an enhancement or defect has not been added to the program, log an Service request for that enhancement. The more requests logged per an enhancement, the quicker the CAE development team will add that feature to the program.
The following enhancements and defects have already been requested:
Bug 1934578
Program Help does not provide information on ASME NCD "Other" tee types
Bug 1934566
Tee Point Dialog does not display previously entered values for some fields when "Other" tee type is used
Bug 1935000
Tee Data Listing input report displays incomplete and incorrect data for "Other" tee types
Bug 1582341:
Syt values in Grids are not same as in Input listing report
Bug 1506646:
ASME NM2 code - Pipe properties - Input grid, enter poissons' ratio automatically changes
Bug 983497:
Localization: Support Tab in Result Grid does not work in Chinese AutoPIPE v12.08.01.010
Bug 748535:
NS pipe sizes are set to 0.00 on Results grids> Support tab> Nominal column
Bug 644227:
Active window changes to input grids after inserting a component
Bug 643905 - 867592:
Incorrect stress unit displayed on General Stress Result grid
Defect 1110592:
Input Grids appear / disappear when deleting objects in a model
Enhancement 167173:
Add results grid tab for Reference node points
Enhancement 152518:
General Stress Table from the output report should be available in the Grids
Enhancement 148665:
Increase the number of characters in the "Line Number" field
Defect 138403: Tracker#: 10317
Update pres/temp cases data when material library or pipe material is changed
Enhancement 136055: Tracker#: 8732
Add total length of pipe to Extended Component Data Listing report
Enhancements Requests and Logged Defects
