| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Warning Message |
| Date Logged & Current Version |
Nov 2022 12.08.03.015 |
The following is displayed when using AutoPIPE
Support_Forces
No Rows returned from Support_Forces!
OK
Why and How to avoid it?
This may have occurred for the following reasons:
1. The model does not contain any of the information trying to be reported (ex. no supports modeled but exporting Support Forces).
2. Filter applied on Quick reports or Report Manager dialog sufficient enough to suppress all node node points in the model from reporting.
3. "Limit reports to highlighted points" is enabled on the Quick reports Input listing or Output Reports dialog.
Avoidance
Use one or more of the following:
a. Insert the type of component needed to report on
b. Remove or lower filter tolerance.
c. Uncheck / Disable "Limit reports to highlighted points" from Quick reports dialog.
Issues that occur when exporting
