KHK Level 2 Piping Code Calculation Issues
Note: Please see the following AutoPIPE help section:
Help > Contents> Contents Tab> Reference Information> Code Compliance Calculations> select a piping code to see the calculations performed by AutoPIPE.
Comments, Questions, and Answers
Question: Can the KHK level 2 option evaluate ground movement?
Answer:
Yes.
Question: Why does Mb2 due to seismic loads in KHK Ss class not include the effect of static earthquake?
Answer:
It is according to JEAC4601 Sec. 4.1 and 4.2.
Question: What is the difference between KHK L2 2000 and 2006?
Answer:
The descriptions on the round off the allowable values are added in the KHK 2006 edition.
