| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Import |
| Date Logged & Current Version |
Nov 2022 12.08.03.015 |
The following is displayed in the model *.MSG file?
*** ERROR: CANNOT PUT TEE AT THIS POINT. TEE IGNORED
What does this mean and how to fix it?
The following was displayed in the model's *.MSG file
TEE A123 W
*** ERROR: CANNOT PUT TEE AT THIS POINT. TEE IGNORED.
*** LAST NODE PROCESSED: A234
There can be any number of solutions to this message, please review know solutions reported.
Solution #1:
While importing OPM -pxf file in AutoPIPE, systems generates an error listing multiple warning and error messages in the *.MSG fie. Upon reviewing this file, take note to both:
WARNING , PXF NODE xxx
*** ZERO LENGTH ELEMENT
TEE xxx W
Come to find out in this case, the OPIM model contained one or more locations where a bend was modeled with 0.00 length. A new bug has been logged (1054206) to restrict creating PXF files through OPM containing 0.00 length components.
Solution #2:
While importing a particular CII file the following message occured:
*** LAST NODE PROCESSED: 4980
TEE 4980 F 0.0000 0.0000
Upon searching the NTL file created during the import process, the following was found:
Investigate both locations
Line 242 appears to be ok
However, line 2151 is confusing as this is talking about putting an SIF on a tee that does not exist. Delete the line 2151.
Save file to a new name.NTL
After saving the new NTL file, use File> Open NTL to open the file.
The file import without issue.
For reasons unknown SIF values were assigned to a tee location that did not exist in the model. Removing this one line and the file could be imported.
Troubleshooting - Import AutoPlant / OpenPLANT PXF file into AutoPIPE
Issues that occur when importing PXF files into AutoPIPE
