| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Load case |
| Date Logged & Current Version | Dec 2022 12.08.03.015 |
Can AutoPIPE correct the ground acceleration record, so that the ground displacement at the end of the record is equal to zero?
Unfortunately at this time, Dec 2022, No. Input the corrected record to AutoPIPEĀ if it is needed.
"Response / Force Spectrum Loads" - AutoPIPE Load Case
