03. Access AutoPIPE Vessel's Private Community
This is a private User Community for downloading Validation and Certification documents that is accessed by members only. Use link here for instruction on how to become a member.
Use the following procedure to log into AutoPIPE Vessel Private User Community:
Step 1: Go to AutoPIPE's community landing page here, Users MUST sign in:
Note: if your see "Log in" in the upper right hand corner, you are not currently signed into to Bentley Communities.
Note: see page here when having troubles logging in
Step #2: After signing into communities, on the AutoPIPE landing page, select the tile labeled "AutoPIPE Vessel Private User Community"
Step #3: After successfully accessing this site, select the tile labeled "Vessel Designer User Community - Media Gallery"
Note: Suggest saving this site to you favorites list.
Step #4: Select and then Download files as needed.
See Also:
Bentley AutoPIPE Vessel
Bentley Select Services Technical Support Webpage
