In order to obtain the access to the Private User Community, users must first become a member. See instructions below to becoming a member:
Step #1: Submit a New Case for Technical support - click here.
Indicate on this case, please provide name and email of the user requesting access to this private site.
This can be found by after logging in Bentley Communities, select the name in the top right corner of the screen, and select Community Profile
Note: If user does not have Bentley Community account, contact the company's appointed Bentley On-site Admin, ask that they add you to the account as a user, and after you have been added as a user, sign into Bentley Communities with the same email as on your account profile and perform the steps above.
Step #2: Wait for email from Technical Support.
The next available analyst will add your name to the private site, and send a response back indicating that person(s) has been added as a member to the community.
Step #3: Access the community - click here
AutoPIPE Vessel Certificate and Verification Documents
