| Product(s): | AutoPIPE | ||
| Version(s): | 2004, XM, V8i | ||
| Area: | combinations | ||
| Date Logged & Current Version | May 2015 09.06.02.06 |
How to define the allowable (ex. hoop, Sustain, Expansion, etc...) for all user code combination in AutoPIPE?
Per the online help:
The Allowable Stress field on the "Code Comb." tab of the Load Combinations dialog enables the user to define the allowable stress for any Code Compliance combination directly.
1. Open the Load combination dialog as imaged below.
2. Default or user Combination:
a. Default Combination, uncheck AutoUpdate check box, see Allowable stress column, change Automatic to stress value as needed.
b. User combination, see Allowable stress column, change Automatic to stress value as needed.
Notes: This field is only enabled when the "Auto Update" check box option is disabled (checked OFF).
