| Product(s): | STAAD.Foundation | ||
| Version(s): | ALL | ||
| Area: | General Foundation | ||
| Subarea: | |||
| Original Author: | Sye Chakraborty Bentley Technical Support Group | ||
I am getting an error message as shown next when I go to view the Calculation sheet. What can I do to resolve the issue ?
Ensure that you do not have any special characters like say "&", "#", "%" etc. in the file name and also in the job name. Check the names of the individual folders and subfolders, in the path where the file is being saved, for any special characters. Also avoid having spaces in the folder/subfolder names. Avoid using special characters while naming the load cases and combinations. This should take care of the problem.
