| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | |
| Date Logged & Current Version | Jan 2023 12.08.04.009 |
**NOTE: The gasket seating condition stresses are calculated using the full available bolt load, where Wg = [(Am + Ab)*Sa]/2... message appears on AutoPIPE's Flange analysis module output report, why?
As mentioned in the note, this indicates to the user that the stress calculated used the full available bolt load ( also known as Design gasket seating bolt load, Wg) and not the:
- Minimum operating bolt load, Wm1
or
- Min. gasket seating bolt load, Wm2
Q. How to calculate Bolt Tensile Stress from Flange Analysis output report in AutoPIPE?
Q. Flange calculation based on Gasket Seating note
