| Reported Major and Minor Shear Values RAM Concrete Column | Product(s): | RAM Concrete Column | |
| First Affected Version: | |||
| Found in Version: | 15.01.00.00 | ||
| Fixed in Version | 15.05.00.00 | ||
| Area: | Report | ||
| Subarea: | N/A | ||
| Defect Number: | 658752 |
In the Concrete Column Design Report, the major axis shear was reported as the minor axis shear and vice versa when GB 50010 was selected for the design code. This was a reporting error only and did not affect the design.
Different conventions were used by the program in the analysis and design components.
Fixed in version 15.05.00.
[[ACI 318 Column Shear Capacity]]
