| Product(s): | RAM Concrete Column | ||
| First Affected Version: | |||
| Found in Version: | 15.01.00.00 | ||
| Fixed in Version | 15.04.00.00 | ||
| Area: | Report | ||
| Subarea: | N/A | ||
| Defect Number: | 374420 |
In the Concrete Column Design Report, the major axis shear was reported as the minor axis shear and vice versa when any code other than an ACI 318 design code was selected. This was a reporting error only and did not affect the design.
Different conventions were used by the program in the analysis and design components.
Problem corrected in version 15.04.00 for all design codes except GB 50010. The issue was fixed in v15.05.00 for GB 50010.
[[ACI 318 Column Shear Capacity]]
GB 50010 Reported Shear Values RAM Concrete Column
