| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Modeling |
| Date Logged & Current Version | Jan 2023 12.08.04.009 |
How to model a Tozen - Axial Covered Type Double Expansion joint using AutoPIPE?
Model it exactly as it is constructed:
Flange, pipe, expansion joint, pipe, anchor, pipe, expansion joint, pipe flange. Contact the manufacture for details on the entire assembly (ex. Pipe dia, wall thickness, length, individual expansion joint data, etc..). This information will be vital when modeling in AutoPIPE.
Flexible Joint - Modeling Approaches, Tips, Techniques
