10. How to Download, Install and License AutoPIPE Vessel CONNECT?
Notes:
    1. 1. Instructions below apply to AutoPIPE version 42.00 to current
    2. 2. CLOSE ALL APPLICATIONS before starting this installation process.
    3. 3. Contact your IT department to be sure that there is no user restrictions for installing software on your computer system. If so, request IT assistance.
The Following procedures assumes:
Installation
Notes:
    1. Create an Offline Installation Package for AutoPIPE Vessel, see kb article here.
    2. Select  from the video to enlarge to full screen mode.
See Video for typical default installation procedure:
Version 47 to present
Version 42 - 46
Licensing
Select here for detailed license information
CONTINUE with Licensing AutoPIPE Vessel
Bentley AutoPIPE Vessel
Bentley Select Services Technical Support webpage:
