Applies To | |||
Product: | RAM Concrete | ||
First Affected Version: | |||
Found in Version: | 15.05.00 | ||
Fixed in Version: | |||
Area: | Design | ||
Issue #: | 719403 |
ACI 318-14 Section 18.10.6.5(a) (and analogous clause in ACI 318-11) requires transverse reinforcement for boundary elements not governed by 18.10.6.2 when the longitudinal reinforcement ratio exceeds 400/fy. Currently, no warning is produced about this transverse reinforcement requirement which may lead to a unconservative design of the boundary elements.
We are working on a fix for this issue.
