| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Library |
| Date Logged & Current Version | June 2022 12.08.01.010 |
The following was displayed while trying to open a file in the library editor:
Invalid Format
Error Reading the source file
Line Number: 198
OK
Why is this appearing?
How to avoid it?
As mentioned in the message, there was an error reading the source file indicated. There could be 1 of 2 reasons for this message:
1. The file contains information that cannot be read by the editor
or
2. The file contains information that is not formatted correctly.
First confirm the file is a default material library loaded from the AutoPIPE file location. Perform the following trouble shooting test, change All Region settings (ex. Country/region, Region format, etc..) to United Kingdom, English (United Kingdom), respectively. Restart AutoPIPE and try to reproduce the issue.
Regardless, of answer, please log a Service Request and provide exact steps to repeat with results of changing all of the Region format settings. Does this region change resolve the issue.
Warnings, Errors, Crashed, Confirm Messages in AutoPIPE
