24. "Graphic" Enhancements & Defects for AutoPIPE
Notes: if an enhancement or defect has not been added to the program, log an Service request for that enhancement. The more requests logged per an enhancement, the quicker the CAE development team will add that feature to the program.
The following enhancements and defects have already been requested:
Bug 1461889
Mode shapes are not animated without first animating displacements
Bug 1090337
Floating Results dialog expands to the same width or wider as the application screen when using the Result > Interactive > commands (ex. Code Stresses, Force and Moment , Restraint , etc..)
Bug 780332
Dialog and Toolbar text should work for other DPI settings besides 100%
805225 - Enhancement
Provide a manual method to choose icon size besides automatic selection based on resolution
686096 - Enhancement
Allow user to customize quick key / hot key mapping for commands
291131 - Enhancement :
TTA - add feature to analyze a Steam filled pipeline
Enhancements Requests and Logged Defects
