Grid Not Visible in RAM
  Product(s): Structural Synchronizer; Ram Modeler
  Version(s): All
  Area:  Import/Export
  Subarea:  Grids
You have imported a repository into RAM Structural System, but the grid lines are not visible in the RAM model.
When you import an ISM repository into RAM Structural System the grids may not be visible. To turn the grids on in RAM Modeler go to the menu Layout > Grids > Select. Select all of the floor levels in the dialog and then check the check box for the grid systems that you want to see on the plans.
Structural Synchronizer CONNECT Edition v.10.00.00.05 attempts to select the correct grid system for each story as it is imported into RAM. You may need to manually select a particular grid system if it is not applied correctly.
Integrated Structural Modeling Home
