| Product(s): | AutoPIPE | ||
| Version(s): | 2004, XM, V8i, CONNECT; | ||
| Area: | Note Message | ||
| Date Logged & Current Version | Feb. 2016 10.00.00.10 |
The following appeared while using AutoPIPE:
Coincident Node Check (Analysis > Model Validation > Coincident Node Check)
Note
N2154-12: Coincident node tolerance is zero, check disabled.
OK
Why?
Typically this note message will appear when trying to invoke the Tools> Coincident node Check command. See AutoPIPE help for details on this command:
Select this option to perform a coincident node check on the complete model based on the tolerance under Tools>Model options >Edit (Coincident Node Tolerance (0- no check))
Review the Node tolerance to be greater than 0.00 before using this command.
